nianiamh
VR6 AUTO ATF CHANGE
Hi all
Is there a filter inside the sump for the auto trans fluid or is it just a case of drain bolt then refill it.
Cheers
There's a filter inside the sump which you can pick up from an auto tranny place for about £15. Make sure you open the cover from teh rear first to allow any collected fluid to drain away from you. Then remove the filter and open the drain hole. Filling is through the dipstick hole so make sure you have a funnel that fits.
