VEEDUBBED
3inch exhaust,down pipe,silencers,wideband...
Right guys,here are a couple of photos of the exhaust system i made on my 2.0 turboed valver,most components were bought from Demon-tweeks such as the various bends,curves,meter long pipes etc.
The exhaust flex i got off eBay.de as well as the two Vr6 turbo center silencers.
I built the system myself working under a jacked up car,no lift,ramps ect so let me warn you if your contemplating such a job that you'll discover a new meaning to back pain,stiff shoulders etc...
It took me around 1 month to cut,measure,weld,fit,remove,re-fit,re-measure,re-fit,adjust,check,align,tighten down,re-position etc,etc.
It's not a job for first timers,lots of swearing involved but if you don't fancy coughing up 500++dollars for a ready-made item,this is what you can do...
