Connorado
Koni TA's... Higher at the back??
The back of my Vr6 is higher than the front... i bought it with Koni TA's all round and as far as i can tell the springs are 40mm Koni's as well.
Is this normal of have they fitted incorrectly, the front is 605mm ground to arch and the back is 640mm!?
.... will it sort it if i get a set H&R springs on there, heard theyre the best combo?
Have a look to see if the bumpstops have been cut. They need to be trimmed by around 40mm.
They can also be lowered by pushing the springplate up and dropping the circlip down a couple of grooves. Can be done on the car by jacking up the springplate with a breaker bar, and then using circlip pliers to move the circlip down.
