JT 0 Posted May 16, 2007 hey, right the oil temp read out on the mfa has gone.. does anyone know which sender it is and where it's located? its a 92 j plate mk2 golf 16v. Quote Share this post Link to post Share on other sites
nocrap 0 Posted May 16, 2007 The sensor (i believe) is on top of the oil filter / exchange housing....these is a green wired one and a yellow wired one. one does the pressure the other does the temp Quote Share this post Link to post Share on other sites
JT 0 Posted May 16, 2007 ahh ok that makes sense.. i thought they were just for pressure but i did wonder why there were two! i can't think what else it could be as all the other functions on the mfa work perfectly. Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 16, 2007 temp sender is small one behind rhs of head, 'round the corner' from the dizzy, small round top usually, that a female spade connector slides on sideways to. ones on oil filter housing are pressure senders, although some later VW engines, e.g. 1.6 SEAT ibiza, has a small temp sender in the third drilling on later oil filter housings, usually these are blank on corrados though. Quote Share this post Link to post Share on other sites
JT 0 Posted May 16, 2007 i had a good clean around that one earlier .. so we will see if it needs replacing:) yeah mine has the third one blanked off.. cheers for the replies guys.. Quote Share this post Link to post Share on other sites
