cvw
where does rev counter get its reading from?
the coil at the side of the ecu ? or te one on the underside of the bulkhead ?
Ignition coil with the main ht lead m8...
I found some rev counter wiring the other day,may be of interest to you...although it may be diffarent on a valver.
Top of the fuse box (g60) there are a few connectors all plugged in from the back,theres a couple of single black wired ones.Unplug either one of these and it stops the rev counter working.
I think its just where the loom from clocks meets loom from engine bay.
Neil.
as neil said the coil with the ht lead,the wiring is completely different on a g60.
regards kevin
