rughead80 0 Posted May 30, 2007 recently my corrado g60 went thump underneath my engine as i pulled up the hill and since then it wont pull away or move or go anywhere :( , the clutch is fine, all the gears go in but when i try to pull away it goes no where and makes a massive grinding noise, has the cv joint bolt broke, help needed, also my 2nd gear crunches ita an 02a gearbox does putting in mt90 redline do the trick, cheers, mark. Quote Share this post Link to post Share on other sites
Goldie 2 Posted May 30, 2007 So the car revs normally bu wont move, are you sure the clutch is connecting?? The Mt90 is very good and does come recommended by many around these parts.. Quote Share this post Link to post Share on other sites
G60_91 0 Posted May 30, 2007 Have you had a good look underneath it? check cv's and driveshafts. Does it grind only when in gear and the clutch out or is it as soon as its in gear its noisy? Quote Share this post Link to post Share on other sites
rughead80 0 Posted May 30, 2007 the drive shaft turns on its own when i start it up but i can reach in and stop it from turnin which i thought was strange. i start the motor in neutral and when i rev it up thats when it grinds really loud Quote Share this post Link to post Share on other sites
drunkenmunkey 0 Posted May 30, 2007 Sounds like a bust differential IMHO Quote Share this post Link to post Share on other sites
