dirtytorque
Interchanging ISV's
many of the ISV's will work on different models, the main problem is that some have slightly different electrical connectors (2 types at least), and on some of them the body of the ISV can be a slightly different diameter and the inlet and outlet hoses in a slightly different postion, best thing to do is compare side by side before buying/fitting if possible, even if part numbers are slightly different.
