Riley 0 Posted June 10, 2007 When i put the ignition on in the G60...the handbrake light comes on albeit dimly.When im running the car its still lit up also. And the handbrake still makes the light come on fully as it should so the switch is working obviously,weird? :? Any idea's? Neil. Quote Share this post Link to post Share on other sites
mrbeige 0 Posted June 10, 2007 Check the brake fluid reserviour, ifthe fluid is low the light will come on dimly. If the level is good, check the low level switch that is in the top is ok. Quote Share this post Link to post Share on other sites
Riley 0 Posted June 10, 2007 Cheers mrB,fluid level is fine...so ill stick a spare cap/switch on and see if that cures it :D Did it a while after i washed under the bonnet so maybe the little pin has water around it or sommet :oops: Neil. Quote Share this post Link to post Share on other sites
mrbeige 0 Posted June 10, 2007 Yup, moisture will be the culprit I'm sure, it was on mine! Quote Share this post Link to post Share on other sites
Riley 0 Posted June 10, 2007 Cool,will just try giving it a blowie :shock: With the air line of course 8) Quote Share this post Link to post Share on other sites
Owen VR6 0 Posted June 12, 2007 I had the same thing on mine when i bought it but after running it for a little while it stopped. I think the guy who had it before me left it standing alot ie... moisture build up Quote Share this post Link to post Share on other sites
Kris Davis 10 Posted February 1, 2014 i've just pressure washed my engine bay, had the same symptoms as the OP.. will be checking mine tomorrow now i know what to look for. thanks for the information.. Quote Share this post Link to post Share on other sites
