cormjah 0 Posted June 12, 2007 Anyone got any advice about this? allegedly next MOT these are gonna fail. can they be replaced/refurbished cheaply? aparrently one of em is seized corroded beyond redemption! Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 12, 2007 PIA did mine a few weeks back, difficult to get at, we managed with it up on the ramps and lowering the subframe and letting it hang front the wishbones still attached to the car, trouble is you can't get force onto the inner joint to un-screw from the rack then if the subframe is loose. I'd imagine dropping the whole subframe is easier, but then you'd need to disconnect and drain the rack unless you can get all the hoses and pump off in one go. My track rods were FEBI ones from AVS http://www.vwspares.co.uk/ and seemed good quality, IRO 20 quid each. new boots are advisable too. Quote Share this post Link to post Share on other sites
cormjah 0 Posted June 13, 2007 cheers for the info david Quote Share this post Link to post Share on other sites
