a98pmalcolm
ABS Light
Hi people, just asking if anyone has had there ABS light come on before, and just stays on. I had this problem for a while now and found out the Relif relay had melted on the fuse box and so i fiddled with the relay and the ABS light would pop off and the electrics would start working, so i bouhgt a new fuse box and relay and then replaced it. All the other electrics are wouking perfect but the ABS light juts keeps coming on from time to time??
Can anyone help please?
Thanks
Paul
There are loads of ABS threads, both in this and the drivetrain section. Have a bit of a look through them to see if your problem is described.
Chances are, you'll need VAG COM to diagnose the error.
Tom
