J a m e s
Metal boost pipes to replace plastic ones?
Here you go Eurosports website they only fit G60's upto 91 unless you change the throttle body hose to the ealier one like i have. I'm only running the cooler to throttle boady one at the mo, the cooler is the most restrictive part of the plumbing so i dont see the sense in the other one to behonest.
You will need to replace the 'O' ring on the pot to get a good seal.
you cant see a pic in my gallery link below.
