Thom
Shaky Corrado
Hi all, I have a problem with my Corrado that I was hoping someone can help me with.
It's a 2L 16v, what happens is, occaisionally, the engine runs very rough, as in, it rattles badly and shakes the whole car!, However, if you turn off the engine and restart it, it nearly always runs smoothly, only to have trouble again later.
Can this be a problem with the injection system, or an HT Lead fault?
Cheers,
Thom :?
Sounds like a sensor or something playing up.......you can get a fault diag done with VAG-COM, this will only give you a rough guide to where the problem lies as the 9a isn't particularly well managed...
If the car runs fine after restarting the engine it probably wont be an ignition fault....
Cheers guys, I'll check that out, I've read through a few other posts and looks like maybe the ISV needs cleaning out, so I'll give that a go too
Ta
