cardboard 0 Posted July 17, 2007 i have just fitted a kr inlet, exhaust and de cat on my 2.0 16v and i belive it is timed up correctly but the engine is poping a lot on down rev and when shifting gear and my mate following me said he saw a flame out of my exhaust when changing gear. also at 4000rpm in 5th it sort of back fires occasionally but not really if you know what i mean!! :? (sort of lurches and drops momentarilly in power but then is fine again). was wondering if this means i havent timed it properly or does it just need a good rolling road session? also can anyone recomend a good rolling road in cheshire or stourbridge area? thanks :D Quote Share this post Link to post Share on other sites
Crasher 3 Posted July 17, 2007 Did you set the timing with the ECU in basic adjustment mode? Quote Share this post Link to post Share on other sites
nocrap 0 Posted July 17, 2007 Timing on a valver was very simple when i did it on mine, the problem was that very minimal movement on the cam is a lot bigger on the flywheel so it's much easier to set it up with a friend looking at the flywheel while you make fraction of a degree adjustments at the other end. Had no need to do anything with the ECU before of after. Quote Share this post Link to post Share on other sites
cardboard 0 Posted July 17, 2007 sorry that is misleading i had a garage do the cam and cam belt as im pretty short of time at the moment so am unsure how they did it but was curious as to whether this should sound like this? it gurgles a lot? Quote Share this post Link to post Share on other sites
nocrap 0 Posted July 17, 2007 Ah ok, no it shouldn't be like that and yes the timing sounds like its out! Quote Share this post Link to post Share on other sites
cardboard 0 Posted July 17, 2007 how can i check the timing sorry if this is basic! i am waiting on the arrival of my passat haynes and am trying to find someone with the pdf of the bentley stuff. i am fairly mechanically minded and willing to learn and tackle stuff so how would i check and alter if necessary the timing Quote Share this post Link to post Share on other sites
nocrap 0 Posted July 18, 2007 No worries, Remove the top cam cover, this will mean you can see the dot / indent on the cam pulley and the arrow on the rocker cover. Basically at this end of the engine you need to have the arrow and the dot lined up. To do this crank the engine using the spline bolt at the bottom of the block where the water pump and alternator belts connect (possibly a 19mm bolt?) Once this bit is lined up go to the other side and remove the bung that is on top of the flywheel / gearbox and see if the line lines up with dot. like i said before a very small adjustment (fractions of degrees) will mean mm on the flywheel which is why it's easier if your have a friend. I may PM you regarding the bently later..... Quote Share this post Link to post Share on other sites
Crasher 3 Posted July 18, 2007 Are we talking cam or ignition timing here? To get the cam timing wrong on a 16v you would have to be a complete numpty. It is more likely that it is an ignition timing issue. Quote Share this post Link to post Share on other sites
nocrap 0 Posted July 18, 2007 well i wouldn't say a complete numpty....it wouldn't be too hard to be a tooth out, the garage could have done the ole tipex timing mark trick so would be even easier to potentially be a couple out... Quote Share this post Link to post Share on other sites
cardboard 0 Posted July 18, 2007 well they changed the cam and the cam belt so it could be either?? yeah? Quote Share this post Link to post Share on other sites
1966robbo 0 Posted July 18, 2007 Agree with all the comments, although I would say it is more than likely that the engine timing is out(which will also affect the ignition timing) and it is easy to set the timing a tooth out. My ignition timing was out, but this only caused starting problems...generally the car run, but did not have any of the symtoms you indicate. As suggested what you need to do is remove the top timing belt cover and rotate the crankshaft pulley as previously mentioned. There is/should be an arrow on the lower timing belt cover. You will need to rotate the crankshaft pulley until the line/mark on the crankshaft pulley lines up with the arrow on the lower casing and the camshaft pulley mark lines up with the marking on the top plastic cover. This will check the "engine timing". As for the ignition timing, this is quite straightforward. Again on the camshaft pulley there should be a line on the outer face. This is the timing mark. With a strobe light, this mark should line up with the marking on the plastic cover. The standard timing is I believe 6 degrees BTDC. I set mine up using the standard marks and it seems to run fine and pull quite strongly throughout the rev range....although 4500 revs up it seems to have a bit more zest. Quote Share this post Link to post Share on other sites
