Bally
wheel bearing noise?
Chaps..
I had front drivers bearing play little while ago.. had it repacked with grease & tighten back up no probs.. mate noticed CV outer boot leaking so Ive got one but havent yet replaced it.. but the noise is still there..
Normal wheel bearings get noiser when turning left or right.. myns seems to be in a straight line.. no change in noise.. constant humming noise.. its almost like dry joint??
I bought a new CV joint too.. but Bill & myself arent sure if its the bearing or something else?
Any ideas??
sounds pretty like a wheel bearing. i just had one front done, prompted by the peristant droning noise in a straight line, with little diff on cornering. I think ? sometimes when its getting more worn its becomes more obvious when driving in straight line. Coulsd also be both fronts are going and noise difficult to localise to which one?
cheers for the reply.. the noise is defo coming from drivers side....
