STORM 2
HELP! urgent tips required
Hi all
I have a front offside seized caliper which I'm trying to take off and service.
I have both the caliper carrier and caliper bolts off but can't get the caliper off as the pads are stuck tight to the disc. I can't even lever something between the pad and disc to try and get the piston back as the pads and discs are quite new (Brembo :roll: )
Any tips gratefully received!!
Id try a rubber or leather mallet and try and caliper to slide off the disc and see where you go from there..
cheers guys - managed to get it off with a wooden mallet.
The piston is badly corroded on its outer rim surface - I wire brushed as much off as I could. I tried to get the rubber seal out without much success so have just put everything back together ---just have to wait until it all seizes up again :(
Front calipers are less than that. VW will sell you refurbed parts for about £35+VAT per side.
Thanks Doc,
I've just ordered a pair from VW- £85.59 inc VAT for a pair of front calipers inc exchange. Not bad at all really
