iow_corrado_g60
Possible big issue! G60!
Hi all ,
not sure if this is a big issue ill do my best to explain as i have no pics as yet!
as you look at the cam cover and go right with your eyes past the oil vent on right hand side down the side of the head you meet one of the oil feed braided pipes keep going down the head untill the head meets the block and clutch/gearbox housing! this housing has two cylindrical holes on the top facing up so i can see either the clutch or fly whell sorry a bit vague
can someone help or post pic as to hat should go in these holes?
Cheers Andy
I believe the technical answer is a plastic timing cover thingy.
Should be cheap from VW.. dont know how much of a problem it is if its missing though, as it stops crap getting in the engine..
my old mk1's had like a plastic bung in there, but then again my last mk1 didnt have it there, its basicly just a dust cover, im not sure if my g60 has it there ill go and check and let you know later mate.
not a major matter of life or death really so dont lose sleep over it, but id get one in there sooner rather then later mate as it stops water/coolent if you have a sudden leek going down the hole and contaminating your clutch.
simon
cheers guys thats great cant believe i missed that was more worried bout oil and stuff engine is very dirty will order it asap
glad its nothing too major but knew the last G wasnt like that!
Timing inspection cover - £2 from VAG
Err.. thats exactly what i said. :lol:
It's more kinda rubbery though Baz ;)
if your engine is filthy best thinkg i have ever used to clean one is Wurth Motorcycle cleaner , it comes in a 1 litre spray bottle and its purple, i use it on my motocross bike and tried it in my engine bay and it was awesome!!
