H9 DUB 0 Posted August 21, 2007 Just renewed my brake fluid and flexy hoses, and bled all the callipers but there still seems to be ar in the system as the pedal is still really soft. Heard someone on here mention a bleed point on the clutch master or abs pump. Am i just talking bollocks or does anyone have any pointers ? :( Quote Share this post Link to post Share on other sites
tonedef 9 Posted August 21, 2007 There's a couple of bleed nipples on the ABS pump and then the one I normally find makes the difference is the one on the end of the master cylinder. Quote Share this post Link to post Share on other sites
H9 DUB 0 Posted August 21, 2007 Ok mate will give them a try cheers Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 21, 2007 There is a point on the clutch slave cyl (on top of gearbox) - won't make any difference to the brakes tho... How did you bleed it?? - if it's drivable it's well worth paying £20 to get it pressure bled at VW etc... Quote Share this post Link to post Share on other sites
Tekara 0 Posted August 22, 2007 How did you bleed it?? - if it's drivable it's well worth paying £20 to get it pressure bled at VW etc... :shock: £20 I need to visit your local dealer, id be lucky if anyone acknowledged my existence for less that £60 worth of work at my stealership. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 22, 2007 Ross - have a look when you go in, they usually have a menu of servicing prices and at the bottom brake fluid change - usually about £22 + vat (it's only a 15min job with the kit they have!) Quote Share this post Link to post Share on other sites
StormchargedVR6 0 Posted August 23, 2007 Always do the master cylinder last , it gets last bit of air out . Quote Share this post Link to post Share on other sites
H9 DUB 0 Posted August 24, 2007 Yep bled the master cylinder the other night and it worked a treat, i now have a firm pedal. Cheers boys :D Quote Share this post Link to post Share on other sites
tonedef 9 Posted August 25, 2007 i now have a firm pedal. Cheers boys :D Oooo errrr :lol: Quote Share this post Link to post Share on other sites
