A-J 0 Posted August 22, 2007 I haven't been able to get air through my windscreen vents so I checked the broken selector cog and no matter which way I moved it I still couldn't get it to work although you could here something moving in the heater box. I then unplugged the connector from the blower motor and reconnected it upside down. Now I get air through the vents but only on number 3 whereas before it worked on all numbers. Swapping the connector back around and the blower works on 1-4 but won't put air though vents. ANy ideas? Quote Share this post Link to post Share on other sites
latestarter2 0 Posted August 22, 2007 As everyone has or is suffering from this i've come to the conclusion its a factory fitted design feature!..lol I cant get air out onto the screen either and ive had a new control panel fitted. Quote Share this post Link to post Share on other sites
RS VR6 0 Posted August 25, 2007 There are a couple things you can try. 1. There is a resistor behind the dash that regulates the voltage to the blower. When that goes bad...certain speeds of the blower will stop working. You have to remove your glovebox to get to it. 2. There are contacts behind the control panel...clean them. Quote Share this post Link to post Share on other sites
A-J 0 Posted August 25, 2007 Turns out the wires going into the resistor pack were the wrong way around making the blower turn the wrong way so therefore no air through vents. Quote Share this post Link to post Share on other sites
