andygal
Vagcom codes
Hey,
Scanned my Corrado VR6 1994 today with vagcom and got the following codes. Can ayone please give me any info as to what they mean and how to sort them. Have cleared them and they came back.
3 Faults Found:
00533 - Idle Speed Regulation
10-10 - Adaptation Limit Not Reached - Intermittent
00522 - Engine Coolant Temperature Sensor (G62)
29-10 - Short to Ground - Intermittent
00513 - Engine Speed Sensor (G28)
03-00 - No Signal
I no the G28 will be due to the fact the engine was off when scanned but looking for info on the other two.
Cheers in advance,
Andy
Check the wiring on the coolant temperature sensors and replace them if necessary. They're on the thermostat housing, there's several sensors.. I think the one you want is the blue one ..
The idle speed adaptation limit not reached is probably due to a sticky/stuck ISV.
Car doesnt start first time and also idles high around 1200rpm.
Yep, that would be about right.
