Thom
ECU Chip installation
Hi, I'm considering a chip upgrade for my 2L 16v (1995). Have heard that on some ECUs, the chip is soldered onto the board, rather than in a chip socket. Can anyone tell me which mine is likely to have, I will obviously otherwise open it and look but if I know before I start then I can upgrade my soldering gear (as its all a little old), cheers :)
its only late vrs that are soldered i think.
if you change yours, make sure you put it in the right way,theres a dimple in the end of the chip to make sure it goes in the right way
