crookesey 0 Posted October 15, 2007 right what it is , is that i have built a 16vt corrado and just wanna know what the best gearbox and driveshafts to use. im currently runnin the standard 16v box with a performance clutch and 16v drive shafts all from the same passat gt 9a engine code. the thing i wanna know is , are they gunna be able to handle 300+ bhp as a daily driver. i have heard of some1 using a mk4 golf anniversery 6 speed box and cuttin the drive shafts down a bit. is this possible or will the ones i have be ok. :? Quote Share this post Link to post Share on other sites
belfastfumanchu 0 Posted October 15, 2007 Cant answer your questions, but sounds cool what you've done. What sorta horse power you think turboing it gives you? Quote Share this post Link to post Share on other sites
junkie 0 Posted October 15, 2007 Not sure between the 16v and G60 but i run alot of power, have been for 3 years and i have not fully broke any yet, gearbox is slightly whining now and an outer cv joint is going now. Its the torque that will break things. If it aint broke dont fix it especially if your modifying driveshafts etc, sounds more hassle than its worth if the 1's you have currently work, stick with them until you do break them, then look to upgrade etc Quote Share this post Link to post Share on other sites
