Thom
Fault Codes
Hi,
Have just read the fault codes from my C's ECU and have come up with the following:
00525 : Oxygen sensor, Low voltage
00516 : Throttle Position Sensor - Closed Switch
00587 : Mixture Control Adjustment, Bad ECU Ground/Air Leak/Leaking Injector
My reason for checking the codes is an occaisional very rough idle and hesitation/stalling.
My o2 sensor is only 10K miles old and have checked the wiring around the TPS and for air leaks.
Can these faults all be linked to a fault Throttle position sensor, or is there something else I should be trying first?
Ta :?
Check the wiring to the throttle switch and to the lambda sensor plug on the engine mount bracket. It may just need setting up.
