cardboard 0 Posted October 23, 2007 2 weeks ago a fuel pipe burst and my car has been sat until i got the part i just fitted it now and when i try to start the car i get nothing, like it is imobalised? the lights work etc but nothing to turn the engine over i noticed that my oil light is flashing does this have anything to do with it? a saftey feature or someting, there is oil in the car. thanks Quote Share this post Link to post Share on other sites
nemesis360 0 Posted October 23, 2007 It might be the ignition switch or barrel not turning enough to kick the starter in (quite common)...try turning the key to where it would normally start and give it a wiggle. If it starts you need to find out which of the above is at fault. Graham Quote Share this post Link to post Share on other sites
Dogzyboy 0 Posted October 23, 2007 The Oil Light always flashes with the ignition on. It should go out when the car is running, though unfortunately, you can't get to this point at the moment! :( Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 23, 2007 does the starter click? i.e. is the solenoid working, they have a habit of sticking when old, but usually when the engine is hot as the solenoid is weaker then. Quote Share this post Link to post Share on other sites
cardboard 0 Posted October 23, 2007 no its is like it is immobilised? there is no sound from the solenoid or starter motor at all. there was no problems before they fuel pipe burst, it wouldnt have damaged the car at all would it? might just try push starting it and see what happens?? :? :? Quote Share this post Link to post Share on other sites
Setone 0 Posted October 23, 2007 battery maybe?? cars be sat for a week? Quote Share this post Link to post Share on other sites
nemesis360 0 Posted October 24, 2007 Have you tried my suggestion above? I normally change 2 ignition switches or barrels a month at work. and its got all the symptoms of this fault. Quote Share this post Link to post Share on other sites
cardboard 0 Posted October 24, 2007 sorry yeah i did turn the key and wiggle it but nothing happened Quote Share this post Link to post Share on other sites
nemesis360 0 Posted October 24, 2007 Oh right it was worth a try coz they sometimes work when you do that, IMHO id still say its the barrel or ignition switch. Quote Share this post Link to post Share on other sites
cardboard 0 Posted October 24, 2007 played with some ignition wires and now all appears to be ok! thanks guys Quote Share this post Link to post Share on other sites
