sparks 0 Posted October 26, 2007 hi guys and girls im in the process of buying a set of coilover for my G60 but unsure on setting them up can i just measure from the ground to the wheel arch if so want is the best height or is it more complactied than that i dont want to fit them and lose my great handling at the mo i have g max lowering springs on standard shocks never a good setup hence the coil overs cheers stu ... Quote Share this post Link to post Share on other sites
junkie 0 Posted October 26, 2007 Count the threads while its jacked up then make sure your on level ground then when its down and measure from the centre of the wheel to the most top part of the arch. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 26, 2007 If you're changing to KW coilovers, they come with very good application speficic instructions and also a good guide on how to measure and setup the ride height properly ;-) Quote Share this post Link to post Share on other sites
MK1Campaign 0 Posted October 26, 2007 Awesome bits of kit. I had them on my old MK2 16v. Should be getting some for my new works VW Caddy van. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted October 26, 2007 Highly recomended and as Kev says when you open the box read the instructions and all will become clear! Quote Share this post Link to post Share on other sites
