a98pmalcolm 0 Posted October 31, 2007 Hi people. Im just about done puttin my engine back in from a rebuild but i had to take off my distributor, so i have now put it back on but i dont know which HT lead goes were?? and will distributor be set up correct as i have just randomly bolted it back in? Thanks Paul Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 31, 2007 Take off the cap and look at the thin top edge of the distributor body where the cap sits. On this edge you will find a small notch cut in to the surface. This is for number one cylinder and so if you make a mark on the body of the dizzy, when you put the cap back on, you can see which pole of the cap this corresponds to. Then, on the side of the dizzy, there is an arrow which points in the direction of rotation the rotor arm rotates. Follow this around to the next pole of the cap and that pole is for number 3 cylinder, and then the next is number four and finally number 2, so the order is 1, 3, 4, and 2. Quote Share this post Link to post Share on other sites
