just_say_meth
G60/VR6 clutch
Sorry guys, stupid question but want to get it right!!
Clutch on the G is on it's way out, is it really as simple as buying a VR clutch kit and fitting it? or Have i read too much into it :lol:
Cheers Andy
Cheers Andy
Yes it is.
Clutch diameter is the same for all 'rados regardless of engine type, so a VR clutch will fit any other model and vice versa.
is it the same for flywheels?
No.
The VR flywheel has a different bolt pattern.
The 4 cylinder flywheels are interchangable but certain models of 8v are a different size IIRC.
I've seen kit descriptions with diameters of 190, 210, 211 and 228 mm, what about those? I have a German VR6...and I'm planning on getting a new kit. any suggestion?
Thanks
MM
I second that,the VR6 press. plate has stronger straps so if your upping the power
on your G60,that's a good start.
