a98pmalcolm 0 Posted November 4, 2007 Hay poeple, just had my engine rebuilt, and trying to start the engine. The engine turns well and the fuel is pumping in and all the leads are sparking. The engine still will not start and will not fire up. The ht lead sequence 1 3 4 2 is correct, but does the way the distributor put in block effect the start up???? Please Help Thanks Paul Quote Share this post Link to post Share on other sites
flusted 0 Posted November 5, 2007 yes, set everything to tdc, the rotor arm should point to a small line on the outside edge of dizzy with cap off Quote Share this post Link to post Share on other sites
