crookesey 0 Posted November 10, 2007 hi every1 , im in a bit of a pickle cus ive bought a 20vt inlet manifold (drive by wire) throttle body on the left., and im wantin to ues it on my 16vt engine as a short runner . i know there is a couple of ways of fittin them to the 9a block (weld the bottom half of the 16v inlet to the 20vt inlet) but im wantin to just use an adapter plate so everythin is tidy . the problem is that when mounting it to the block there is a water pipe in the middle of the head in the way. how do i get round this problem. if anyone has any detailed engine pics of the 20vt inlet mounted to the 9a block it would be so helpful as this is the only thing left in the way of gettin it running :( or any info on this problem would be great 8) Quote Share this post Link to post Share on other sites
flusted 0 Posted November 10, 2007 you can mod the water outlet or i believe bbm make 1 that will give you clearance Quote Share this post Link to post Share on other sites
crookesey 0 Posted November 10, 2007 is this the coolent flange that they make , its near the bottom of the page. cheers bud http://www.bahnbrenner.com/vw_audi/prod ... ka_Da_BOMB Quote Share this post Link to post Share on other sites
