kop10320178
engine stalling
hi
i own a 94 rado vr6
recently when slowing down the engine is stalling, sometimes it drops to 400 revs,
are there any simple checks i can do or does it have to go in to vw.
thanx jay
Welcome to the forum! The problem you have is very, very common, but I'm afraid it can be caused by any number of things e.g. ISV, MAF sensor, coilpack, plugs/leads, relays, throttle body, throttle cable, throttle damper position etc.
Most likely causes are ISV and MAF. You can remove the ISV and give it a good clean and lube.
Best thing is to do a search as it's been discussed soooo many times!
Also, I wouldn't take it to VW! Find yourself a good specialist instead ;)
