CIPO 0 Posted November 15, 2003 Anybody any ideas as to why my blower is only working on the number 4 setting????? Cheers. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 15, 2003 the resister pack (rheostat) or the thermal fuse on it has gone... IE you have no resistance Have a search on here and you should find some guides to fix this. http://website.lineone.net/~quigger/heater.htm Quote Share this post Link to post Share on other sites
Tattie 0 Posted November 16, 2003 thermal fuse from maplins cost around £3 including delivery. Just have to be able to use a soldering iron (one end of the thermal fuse only). You have to remove the shelf below the glove box. You should then see the fan in the LH corner. The shiney metal electrical connection is the fuse/resistor pack. Remove the fuse/resistor pack by levering the metal plate away from the fan housing AT THE TOP. Its held in by a bit of sealant and a plastic 'groove'. Take off the 2 connections and then you can take the fuse/resistor pack out of the car to work on. The thermal fuse looks like a resistor with a white pointy end. The connection at the white pointy end is 'crimped' to the mounting post (more like held in with a piece of bent metal clip!!). The other end is soldered on. Just replace this and away you go. I got the gen off that link too. Approx 45 min job Quote Share this post Link to post Share on other sites
vr6storm 0 Posted November 16, 2003 thermal fuse from maplins cost around £3 including delivery. :shock: :shock: :shock: they charge £2.50 for delivery??????!!!! :shock: i bought 2 from my local maplins for about £0.90p just a couple of months ago Quote Share this post Link to post Share on other sites
dazG60 0 Posted November 27, 2003 Hi does any1 know if the resister in my c is the same in any other vw,ie-if i went 2 the scrappy could i get 1 out of the mark 3 golf etc :? G60 Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 27, 2003 I don't think so as its the only car of that age to have a 4spd setting, the mk3 is alot different. I managed to get a corrado from a scrappy for a £10er... Quote Share this post Link to post Share on other sites
