yogiontour
New VR6 engine
Good source for a new engine.
My VR6 decided to die the other day...Water streaming from somewhere with a seperate pool of oil....:(
It sounds like its going to be expensive, I was just wondering whats a good price / source for a new ish VR6...Do vw still supply them?
I say this as im going to need to balance this price against a rebuild.....
Its all very sad :(
Spot the glass-half-empty person!
VR6s rarely die so badly that they're written off! It just sounds like you probably blew up the oil cooler or something .. !
Iff it's *that* dead, you might be lucky on getting a complete engine from VW for a reasonable price, but it will be a rebored 2.8, the only full block 2.9s left are hugely expensive. I've heard a number of tales of woe around VW refurbed engines too, but at least the warranty on them is unbreakable (you just have to keep going back)..
Other than that a VEGE refurbed engine will cost a couple of grand fitted, and a full rebuild will cost £2-3k too. TBH a lot of people are finding that the 2.8 24v transplant is a good way to go for about the same cost.
I do have a habbit of being very pesamistic, I'm going to spend my lunch hour trying to find the fault...but at the moment its nothing obvious....The HG seems fine though...hmmmmness....
I would love a 24v turbo engine....it all seems very complicated though...
I'll go check at lunch what the fault is before i jump the gun 8)
I have several 2.9 corrado vr engines,one still in the car running,so you can try bedore you buy
