M15 VW 0 Posted December 2, 2007 Anyone know what the oil pressure on a vr should be at cold and at 90 degrees? Quote Share this post Link to post Share on other sites
M15 VW 0 Posted December 2, 2007 Just found this out. 4 bar when cold, 2 bar at normal running temp. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 2, 2007 That's the figures for 2000 rpm iirc. There are four data points to match up if you're testing "by the book", including another two for hot/cold operation at 4000 rpm. Quote Share this post Link to post Share on other sites
M15 VW 0 Posted December 2, 2007 do you know what they are? Quote Share this post Link to post Share on other sites
fla 9 Posted December 2, 2007 How and where do you measure the oil pressure? What kind of gauge do you need and where can you get hold of one? Quote Share this post Link to post Share on other sites
M15 VW 0 Posted December 2, 2007 How and where do you measure the oil pressure? What kind of gauge do you need and where can you get hold of one? You measure it from the oil pressure switch at the front of the engine above the oil filter. Any pressure guage that reads up to 6 bar will do. Most tuning places should have them or demon tweeks etc. Quote Share this post Link to post Share on other sites
fla 9 Posted December 3, 2007 Is there any other place where a physicl pressure test can be done? Iwant to see if there's sufficient pressure in mine by the cams, if thats possible (related to the tapping noise) Quote Share this post Link to post Share on other sites
peanut 0 Posted December 3, 2007 Get a screwdriver and place it different ares of the engine (with it running) and try and trace where its coming from. Try the head of the tensioner bolt too. Quote Share this post Link to post Share on other sites
