ValRado
Would a mk2 gti rad fit a 16valver?
AS per the title, I need a temporary repair to my car as the rad is peeing out now. I have a rad off a mk2 8v gti somehwere. Anyone know if it'll fit before I start taking bits off?
Thanks!
Paul
no, it's too long, what you need is a 430mm one from a 1.6 carb golf mk2, same size as a 16v corrado one just not quite as efficient, perfectly up to the job though unless the weather changes to 35 degrees or you use it as a track car :)
