barker44 0 Posted December 10, 2007 after drying the passenger footwell up, i tried my electric windows to check the window seals and let abit of air in........the passenger side window did not work (although an hour before it did) but now there is a clicking noise from what sounds like a relay module coming from the drivers side somewhere so the relays seam to be working. i tried to take the door pannel off to have a look but some kind of hidden screw or something stopped me by the speaker and i gave up bfore i started kicking something and throwing tools around......... lololol The drivers side window does work though..... Any ideas? Quote Share this post Link to post Share on other sites
Goldie 2 Posted December 10, 2007 There is a screw towards the front of the car by the speaker, remove the grill and you see it... Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 10, 2007 yes, get down low and look up into the speaker surround, its at about 1pm if it were a clock :) Quote Share this post Link to post Share on other sites
easypops 8 Posted December 10, 2007 my passenger window stopped working for about 4 months.....got a new motor and mechanism...but never got round to fitting it :? .....then one night about a month ago i went through a big puddle...... and splashed a few people by accident .....got caught in traffic and two wet people got into the car....one on each side and set about me :shock: ....a few kicks to the head and a bit of abuse and they were off.......slamming the doors as they went.......leaving me a bit sore but not too bad considering.......but then on the way home i happened to try my passenger window(did this now and again as i could hear a click)and it worked :lol: i wouldn't advise this.....but your motor/mechanism may only be stuck good luck :D Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted December 10, 2007 easypops said: my passenger window stopped working for about 4 months.....got a new motor and mechanism...but never got round to fitting it :? .....then one night about a month ago i went through a big puddle...... and splashed a few people by accident .....got caught in traffic and two wet people got into the car....one on each side and set about me :shock: ....a few kicks to the head and a bit of abuse and they were off.......slamming the doors as they went.......leaving me a bit sore but not too bad considering.......but then on the way home i happened to try my passenger window(did this now and again as i could hear a click)and it worked :lol: i wouldn't advise this.....but your motor/mechanism may only be stuck good luck :D " two wet people got into the car....one on each side and set about me" do you drive a mcclaren F1? :! Quote Share this post Link to post Share on other sites
easypops 8 Posted December 10, 2007 Quote " two wet people got into the car....one on each side and set about me" do you drive a mcclaren F1? :! one came in the passenger side head first trying to grab/punch....while defending myself against him.....which aint that easy sitting down with a seatbelt on....the other dude opened the drivers door and introduced me too his boots.......so you dont have to sit on the middle for them both to get you......not something i'd recommend anyway :D edit....just re read what i said originally.......ok they didn't exactly get ''in''......but they got in enough :D Quote Share this post Link to post Share on other sites
barker44 0 Posted December 10, 2007 lolol, lucky they didnt drag u out and start at u. thanks for the info ill try slaming the door a couple of times lolol, like i said the motor worked 30min before Quote Share this post Link to post Share on other sites
