weskos
Anyone know where this sensor goes? (G60)
On the left hans side of the ISV there is a white plug, well if you trace the wiring back there is aslo a brown wire with a sensor on it, where abouts is yours plugged into as i cant seem to find a hole anywhere? Id REALLY appreciate it if someone could just have a quick look and see as its driving me out of my mind. Thanks. :scratch:
no its a G60 but it could be the same. The ISV is on top of the rocker cover towards the back. Its a cylinder shape with a pipe on one end and a white sensor on the other. Thanks mate thatll be a huge help!
Best guess is that is the fuel pressure sensor for the over run fan/fuel pump activation when the engine is off to prevent fuel vapourisation when the engine is hot.
It should plug onto the sensor that comes off the fuel rail.
All the fuel rail sensoors are plugged in. It has a bracjket fitted to it aswell, kind of a 'L' shape. Its a bras cylindrical shape with thread around 8-10mm in diameter.
Anyone any ideas?
