stevej
will it fit ?
feel a bit thick asking but will a magnex cat back exhaust system from a 2.0 16V fit onto a 1.8 16v no cat ??
thanks
as long as the connections from the down pipe are the same, and hangers as already mentioned which i think they are then yes.....but you will lose a little power by adding a cat...why do you want to do that??
thanks
He said cat-back, ie: no cat :lol:
sorry, its going from a 2.0l 16V with a cat to a 1.8 16V with no cat. so not adding a cat. i have the chance of getting a 1.8 and thinking what i can potenially swop between the 2.
shouldn't be a problem with the back and centre sections, i beleive that the front pipe connections will be different but the magnex should have been supplied with an adaptop......
thanks
oh yeah...didnt read it right...thought he said cat combined back box....im so sorry you felt the need for correction there! :shock:
thanks
as long as the hangers are the same then yes.
the hangers changed on the facelift and change to the 2.0 16v, so no, a 2L system wont fit on a 1.8 without welding new hooks to the system or hangars to the car.
