cabby-67
vacuum hoses behind intake????
There are two ports on back of intake, one for ecu and one for other. I noticed that they were both bad. I removed them and clipped them back for a better connection. Yes, I know now the ecu one has to be exactly 1 meter long by 3.5 mm. I will get that line today. However, I am not sure if I placed the hoses in the right posistion.
My question is.....where does the ECU vacuum line go, top or bottom.
BTW, I did finally get is started. Dizzy was good, had to reintroduce voltage backwards from dizzy, must have been a stuck relay or something.
Getting a new muffler today as old one is bad. Any recommendations? Magna or Flowmaster??
Thanks all.
$500 for corrado, now another $1500 later. Total investment $2000, what was I thinking. I hope the Ladder G60 will last for some time, I know I will have to rebuild it soon, now at 100,000 miles on OD.
Can someone elaborate a little on the ECU vacuum pipe having to be exactly 1m x 3.5mm? I have never heard of this. Presumably the volume in it is critical to correct ECU operation?
Thats right
I just replaced mine as the PO had put one on that was 104cm long and an id of 3.2
made quite a difference higher up the rev band presumably because it wasn't getting enough fuel . (higher revs air flow/mass)
