georgek
Starter solenoid sticking, what are the options?
Hi all,
Had the AA out this morning as the VR wouldn't start. Guy gives the starter solenoid a whack with a bar and all is fine. Problem is it needs a whack to start every time now :(
Is it new starter motor time or is the solenoid able to be removed and fixed separately?
Are these jobs that I can do myself? I don't mind having a go.
Thanks
George
yep, the solenoids come off, easy job, they get weak over the years and stick usually when hot (the electro magnet is weaker then).
I think it may be hard to source just a solenoid though, second hand is your best bet, careful with non-VW exchange starters though, they've not got the best reputation for longevity.
It's worth removing the starter and cleaning it up/check the carbon brushes too if it's old enough for the solenoid to be playing up. It doesn't help that the wiring to the solenoid deterioriates, I've seen a few people relay up the solenoid feed from the ignition so it gets a full 12V from the battery direct. Earth straps could do with checking/cleaning replacing if necessary too.
Took the solenoid apart and gave it a good old clean, replaced and all is well again!
sportsman's bet it fails on you again when the engine is hot sometime tho...
HI
Hope you took some photos for us.
Well, it's gone again so you win! I'll get a new/reconditioned one.
