Tekara 0 Posted January 20, 2008 I'm in need of having my wheel alignment done again after renewing the front top mountings. Does anyone know what settings Stealth racing currently use on Rado VR's? I had the alignment done by Vince before Christmas and it was the best its every been, and id like to get a local place to try and replicate as a stop gap before I can get back up to Stealth. Quote Share this post Link to post Share on other sites
Jim 2 Posted January 20, 2008 It should just be as it is from VW.. did you not get a print out with all the values on when you had the work done? I got two pages of alignment info after I had my car done there last! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 20, 2008 Stealth use a Beissbarth machine - most big VW/Audi dealers have these... Quote Share this post Link to post Share on other sites
Tekara 0 Posted January 20, 2008 Sadly i didn't get any print outs, and i forgot to ask at the time. I don't think it was setup using stock VW settings, as i recall Vince saying that my tyres would wear a little quicker with the setup used. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 20, 2008 Worth giving him a call Ross - he may have it saved under your reg... Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 20, 2008 Stealth usually give you a print-out which shows you all the measurements and readings, but ottomh it's approx: front camber ~ -1.2 total front toe ~ 0.0 front caster angle ~ 3.0 Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 21, 2008 Vince sets camber to - 0.8 Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 21, 2008 geometry settings nr end of this thread Quote Share this post Link to post Share on other sites
carpoid 0 Posted January 21, 2008 Thats cool, i need to get mine done too, but would the settings vary on individual set-ups? i mean different ride heights/ wheel offsets and sizes etc. Cheers Matt Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 21, 2008 Vince sets camber to - 0.8 He didn't on mine. -1.2 both sides .. ;) Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 21, 2008 Thats cool, i need to get mine done too, but would the settings vary on individual set-ups? i mean different ride heights/ wheel offsets and sizes etc. Cheers Matt best to try factory settings for camber and toe and see how you like it, too much -ve camber and it'll go round corners great but chew your tyres up. Quote Share this post Link to post Share on other sites
carpoid 0 Posted January 22, 2008 Thanks for that, just seen it my Bentley Manual, got the car booked in at a VW stealership who have just got the Beissbarth machine that Stealth use. Stealth set mine up when i had the Coilovers put on so hopefully it will feel like it did when Vince set it up !! Matt Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 22, 2008 Probably, it'll just cost more ... Quote Share this post Link to post Share on other sites
carpoid 0 Posted January 22, 2008 $120, about 50 pounds, not bad i thought, that includes balancing wheels/tracking. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 22, 2008 Ah, life is cheap outside the UK ... Quote Share this post Link to post Share on other sites
Junior Jackson 0 Posted January 24, 2008 Our (JCT600, formerly Priory Park) dealer in west Hull is currently charging £74.00 an hour labour... Chris. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 24, 2008 Vince sets camber to - 0.8 He didn't on mine. -1.2 both sides .. ;) Sigh.... let me rephrase it then..... Vince sets it to -0.8 unless specifically told otherwise!! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 24, 2008 Sigh.... let me rephrase it then..... Vince sets it to -0.8 unless specifically told otherwise!! I didn't tell him to set it to -1.2, I said "do a 4 wheel alignment" and he set it to -1.2. I'm not arguing, I'm just telling it like it is .. Maybe he does it differently for your big arse wheels with your lowered suspension compared to my all-standard setup? Perhaps you are the unusual one, Mr Cheese Strings? ;) Quote Share this post Link to post Share on other sites
dinkus 10 Posted January 24, 2008 I just had mine setup for -1.0 camber at the local place. Cos I asked them to. TBH it's all a matter of personal preference. If you do lots of motorway driving then having uber -ve camber will lunch the inside edges of your tyres. If you do lots of twisty back-road driving then less camber means you don't get such good turn-in. The factory setting is in the region of -1.5 to -1.6 But it is a range to be within spec and it's not a highly-strung race car on rock-hard suspension driving on a perfectly smooth race track. You're driving on a whole range of different surfaces in different weather conditions, different temperatures and different levels of heat in the tyres. 0.2 degree here or there might make a little bit of difference to your tyre wear over the course of a few thousand miles, but it's really not something worth losing sleep over. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 24, 2008 The factory setting is in the region of -1.5 to -1.6 -1.2 actually :lol: Maybe he does it differently for your big arse wheels with your lowered suspension compared to my all-standard setup? Ah that's a point, you're running standard ride height? :lol: In that case, yeah he uses the standard camber. -0.8 must be what he's found is best on lowered C's ;-) Quote Share this post Link to post Share on other sites
