Dub_nut_g60
Where could my oil leak be from??
I finished my engine swap at the weekend, unfortuantely there was oil running out of somehwere (i susspect the oil filter housing gasket) and also 2 spot of oil towards the front of the bay, think possibly from the oil cooler.
Went to the car on monday night to find oil covering all the pulleys and the whole side of the engine. I havent had chance to look where its coming from (and as its covered in oil its not going to be easy to tell!!)
Does anyone have any ides where the oil could be coming from? lines going to/from oil cooler? rocker cover gasket? or worse, supercharger?
Engine was apparently running fine in the old car so can only imagine its something ive done, or a seal has blown over time where its been sat around.
take the grill off and check the oil return isnt leaking from the charger, other than that possibly rocker cover or sump gasket?
