blue95
OEM Heat Exhange removal
I am planing to get mocal oil cooler and wanted to dump the OEM cooler, does anyone know the part numbers for the pipes to bypass the cooler???
Thanks
They are on here is you search but it's basically the 2 equivilent water pipes off a MK1 so VW should be able to find them in seconds - about £15 the pair...
Thanks
Must be typing in the wrong search criteria....will try again for part numbers :)
JUST GOT SOME MY SELF
027121063C £7.82
026121053G £14.54
YOU NEED TO CUT DOWN THE THREADED UNION ON THE FILTER HEAD OR
BUY A NEW 1 COST £7 CANT FIND THE NUMBER AT THE MO
027121063C £7.82
026121053G £14.54
Cheers
What motor you got???
As the lower hose will not fit on mine, as the bottom pipe that feeds the heat exhanger comes off the lower metal pipe.
Think its different on the early valvers.....anyone on a 9a done away with these pipes????
If not anyone know where I can buy a rubber end cap?
G60
GONNA DO IT THIS WEEKEND HOPE FULLY
THESE PIPES ARE mk1 PIPES I THINK
THE BOTTOM PIPE HAS A LARGE END AND THEN REDUCES TO SMALL END
IF NOT LEAVE EM ON AND BLOCK THEM OFF
ITS HARD TO WORK OUT IF YOUR LOOKING AT THE SCREEN IN VW'S
AS ALL THE PIPES ARE DISPLAYED ON THE 1 PAGE, SO I GOT THE NUMBER OF MY MATES CAR
