vw domo
strange crunch sound?
thers this crunch sound when i pull away, it only does it once after starting her up.
it kinde off sounds like gears crunching and i can feal it through the clutch peddle, but still does it roaling out of gear.
saw how helpfull you guys where on some other posts and thought you might have some idea of the problem before something goes wrong, again :? . thanks :D
ye, sounds like the crunch is the abs test, it does it when the abs kicks in as well, only on that front drivers side wheel though.
don't really know how the system works so have been reluctant to have a look, thought it might be the caliper? thanks edd
