Chris
speedo time/trip display light question
when i turn the lights on all the interior lights work fine, only one which doesnt is the trip/time display in the speedo, milage lights up fine.
im assuming that the bulb has gone, does anyone no how to check/change it? i had the face of the speedo off and the fuel/temp gauges out but the time display attached to the pcb, does that need to come out?
chris
Seem to recall its a 'clocks out' thing, but you don't need to take the clocks to bits (you can get at the bulbs from the back of the clocks unit).
It's just a bulb that plugs in the back dude - you need to take the clocks out as a unit...
It's a special bulb in a holder you need - 12v 1.2w Osram 509T - can get LED replacements now...
