kevg60 0 Posted March 6, 2008 hi i just drove g60 and steering started yanking to the left it only does it when i put my foot on the acclerator does anyone know whats wrong with it now cheers in advance kev Quote Share this post Link to post Share on other sites
mic_VR 3 Posted March 6, 2008 Check tyre pressures, if you've not changed anything geometry wise a difference in tyre pressures can make a big change to the way it pulls. I had a mk2 golf that pulled to the left all the time because the rear passenger tyre had a slow puncture. Quote Share this post Link to post Share on other sites
kevg60 0 Posted March 6, 2008 i dont think its tyre pressure when i go slow and litely press the pedal it yanks steering wheel to the left every couple of seconds and as i pick up speed it yanks faster (this sounds dodgy) Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 6, 2008 Sounds serious.. CV joints/diff/drive shafts would be my guesses.. Quote Share this post Link to post Share on other sites
kevg60 0 Posted March 6, 2008 yeah most proberly will be serious knowing my luck with this car. my gues is driveshaft or diff just thought i see if this has happend to anyone else Quote Share this post Link to post Share on other sites
Lufbramatt 0 Posted March 11, 2008 does it pull backt he other way under braking? check all your wishbone bolts, should be really tight else the wishbone was move around, depending on what ones loose decided what ay it pulls. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 11, 2008 it could be the torque-steer reducer has come loose and slipped down the driveshaft. This looks like a small band of metal on the driveshaft. Quote Share this post Link to post Share on other sites
ben16v 0 Posted March 11, 2008 it could be the torque-steer reducer has come loose and slipped down the driveshaft. This looks like a small band of metal on the driveshaft. isnt that a vibration damper and doesnt really do anything, when they come loose just cut them off - never noticing any difference Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 11, 2008 Pretty sure they are to eliminate the torque steer due to unequal length driveshafts, but I could be wrong. Quote Share this post Link to post Share on other sites
ben16v 0 Posted March 11, 2008 if i had any torque! :lol: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 11, 2008 if i had any steering! :lol: Quote Share this post Link to post Share on other sites
kevg60 0 Posted March 11, 2008 cheers for the replies just to confuse me even more it stoped doing it but know theres a dodgy noise coming from the left hand side i think its the cv joint got my MOT next week so i will get the garage to look at it Quote Share this post Link to post Share on other sites
