8vtornado
drive shaft and damper?
iv noticed my driveshaft damper on the o/s has perished and the outer has detached from the inner causing it to flop around and make occasional noise. my question is this; can you get a new one or do you have to get a new driveshaft? and where can i get a new driveshaft complete with damper from? and come to think of it, do i even need it? thanks
cut mine off, it was just sliding around anyway as the paint is all flaking off the driveshaft, doesn't make any difference as far as I can tell, VR6's don't have them anyway, not sure you can even buy them from VW without a complete driveshaft, if you refit one then there are precise measurements about exactly where it goes:
thanks for the replys, ill whip it off then!!! surely if theres an exact measurement for it then it must be of some importance?
