myles 0 Posted March 22, 2008 looking for help. 95 corrado vr6 starts but cuts out after two seconds.i have disabled the cobra alarm and it does not change things. the car was running perfectly up until this problem. it reminds me of a fault in the old ignition systems when the feedback to the coil was broken. anybody got any ideas, thanks a million. Quote Share this post Link to post Share on other sites
VR6 0 Posted March 22, 2008 Engine would be a better place for this. Moving. Quote Share this post Link to post Share on other sites
nick vr6 0 Posted March 22, 2008 Check fuse no 16. 15 amp fuse. Quote Share this post Link to post Share on other sites
tonedef 9 Posted March 22, 2008 Or the immobiliser, had the same thing with mine and fixed it by swapping the reader coil around the ignition switch. Quote Share this post Link to post Share on other sites
nemesis360 0 Posted March 22, 2008 Probably the imobiliser, the connection for the reader coil can get a bit groggy after a while so it might be worth disconecting the plug and spraying some wd40 in there and see if it cures it. Follow the wire from the reader thats wrapped round the ignition barrel to the box under the dash and thats the connector you need to clean. Graham Quote Share this post Link to post Share on other sites
myles 0 Posted March 22, 2008 thanks a million lads, six pack is burbling again !! number 16 fuse gone. Quote Share this post Link to post Share on other sites
