coolrado
G60 injector pintle caps, suppliers?
Anyone have any idea where these can be bought from seperately or as part of a complete injector seal kit?
i very lightly tapped the end of one of my injectors with a spanner as i was tidying up and it has cracked the very brittle pintle cap.
VW do them as a seal kit - 030 198 031 (which is Bosch 1 287 010 704)
Or, seperate bits can be bought from Bosch...
In the above kit you get -
1x 1 280 423 712 = Protective sleeve (Yellow)
3x 1 20 210 711 = O Rings
1x 1 280 320 052 = Support Ring (grey)
Hijacking the thread, can you obtain the same kits for VR6 injectors?
if they are the same type of injector (bosch with 4 small discharge holes) they should be the same ones, just ordered 4 of the kits from a local bosch dealer, £2.07 per kit.
obviously the only difference for the vr is you would need 6 kits.
