monVR6 0 Posted April 19, 2008 Hi all Just about top go for a spin in the VR a bit earlier this afternoon and it seems to have developed a knock from (what seems like) the top of the engine - it seems louder with ears near the throttle body. Now, it was fine when I last drove it - so not sure what has caused this? The car has done 90K miles - could this be the early signs of the chains needing doing? If it is the chains - can it be driven like this - or is there potential to do more damage? Anything else it may be? Thanks in advance everyone . . Quote Share this post Link to post Share on other sites
mattkh 0 Posted April 19, 2008 Hi The chains are not on the side of the throttle. Any chance of recording of the noise. Quote Share this post Link to post Share on other sites
tandino 0 Posted April 19, 2008 Tappet noise possibly? Good idea about getting a sound clip. Quote Share this post Link to post Share on other sites
monVR6 0 Posted April 20, 2008 Hi all Thanks for the thoughts - had a bit of a closer look today and it looks like plug number 5 is almost undone - and actually wobbles about in its' socket - as this is where the noise seems to be coming from - I'm thinking this is a good thing to do first! Only thing is - is there a special tool I need for this? Cheers Quote Share this post Link to post Share on other sites
mattkh 0 Posted April 20, 2008 Hi The special tool is to make sure you get the HT lead out without damaging it. Quote Share this post Link to post Share on other sites
monVR6 0 Posted April 21, 2008 Hi again So plug number 5 was loose and after tightening - everything was back to normal - a great relief as I had hideous visions of this being hugely expensive :clap: Hope this may be helpful to others whose VRs suddenly develop such a noise - I only discovered the solution by accident really :roll: Cheers all - and thanks for the input . . Quote Share this post Link to post Share on other sites
mattkh 0 Posted April 22, 2008 Hi again So plug number 5 was loose and after tightening - everything was back to normal - . Hi Glad to hear that. I just want to know if it is possible to whip the lead out and push it on without the special tool. Quote Share this post Link to post Share on other sites
mariojoshi 1 Posted April 22, 2008 Because of how deeply seated they are under the manifold, the only way really is to pull on the lead, risking breaking the connection. Personally, I wouldn't. The tool actually grips onto the metal part of the socket, meaning you can't really damage it. Quote Share this post Link to post Share on other sites
monVR6 0 Posted April 22, 2008 Agree the tool would be best - as it was number 5 plug for me - I was able to get a good grip on the body of the cap from under the cover to remove with my uncommonly small hands and ET-like fingers. Other cyliders will no doubt be a pain in the . . . to remove . . Quote Share this post Link to post Share on other sites
