donnyburger
Engine running on.
Hey guys, anyone had a problem with the cae continuing to run when ignition is switched off? First time it was quit amusing, as i had the key in my pocket and the car was still running! Second time has become annoying though. Have to stall to stop. Any advice or just a technical gremlin?
hi
ignition switch
rich fuel
or to much carbon build up
depends if its a horrible running on
or if its sounds normal when its doing it
it cant be the ignition pack unless its still got a voltage going to it and that would be the ign switch
Not knowing the engine doesn't help....i had (touching wood) a similar problem on my 16v 9a, changed the 5th (cold start) injector gasket and haven't had the problem since....coincidence maybe.
