jack
VR6 idle
hi folks, when i start my car for the first time in the day it has an uneven idle, the revs go up just over 1000 and back down, they continue to do this for about a minute and then everything is fine, any ideas of what is causing this.
On cold start, the idle should be up around 1000, but should be even. It will then drop slowly to around 650rpm. As said, give the ISV a good clean and check for airleaks in the intake pipework.
